CFM question
Old Sep 29, 2007 | 10:10 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
CFM question
Does anyone know how many cfm's the stock dual electric fans pull?
Old Sep 29, 2007 | 06:30 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: CFM question
Joe, I don`t know and I have not been able to find any info about how many cfm`s the stock fans produce. I recently installed a 4th gen dual fan shroud in my `88 383 TPI Iroc and what a big difference that made. I can`t believe how much cooler it runs. Let me know if you want any info about the shroud. I use a 200 on 185 off fan switch and I could not get my car to run over 200 all day no matter how long I sat in traffic or let it idle. Everything else in the cooling system is stock except the fans ,shroud ,fan switch and thermostat.
Old Sep 30, 2007 | 09:41 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: CFM question
which fans did you go with?
84z96L31vortec
Aug 20, 2017 12:16 AM
formula_novice
Sep 5, 2015 03:58 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
