What Would Cause This?
Old Oct 3, 2007 | 02:19 PM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Hi guys! My 1992 RS had been sitting for 4+ years and I recently got it going again. Went through hell getting it roadworthy after sitting, and fixed the problems that caused me to park it all those years ago. A new problem has reared its ugly head now. My radiator is leaking on the driver's side, it appears the plastic tank on that side is separating from the aluminum part; or maybe whatever seal there is bad. I don't have a problem with overheating, and I can replace the radiator myself, no problem. Just wondering what might have caused the leak? Any ideas?
Thanks!
Dave
Old Oct 3, 2007 | 03:44 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: What Would Cause This?
i think its just age. my radiator just cracked one day. it happens to all cars with plastic tanks. i've seen it happen mainly to toyotas though.
Old Oct 3, 2007 | 03:59 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
just old age , change radiator , fix other things and enjoy .
Old Oct 3, 2007 | 04:02 PM
1989karr's Avatar
Engine: 3.4 / 5.0
I agree! You also might as well change the radiator hoses while you're at it too. Its cheap and easy to do, and will save you some headache down the road.
Old Oct 4, 2007 | 06:48 AM
Big Dave's Avatar
Thanks, guys. I figured it was just an old age/worn out part sort of deal. The car has never had a problem with overheating, at least not in the 8 years I've owned it.
I grabbed a radiator from the local junkyard... hey, it was a mile away and $25, plus its guaranteed for 30 days. I figure if it leaks too, I'll take it back and just go buy a new one. Might as well save a couple bucks if I can.
I'm gonna leave the hoses alone for now, they're relatively new and in good condition.
I'll be keeping a close eye on everything on this car, since it sat so long. More things are bound to happen. I'll replace parts as necessary.
Dave
