new useage for a/c CONDENSER?????
Old Oct 5, 2007 | 02:49 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
OK... You guys helped me remove my a/c components.
NOW im wondering if i can REUSE my AC condenser (i think im saying the right part. Its the little radiator in front of the big radiator!).
I would like to Use it as a trans cooler........ANY THOUGHTS??? do's or dont's?
newb.
Old Oct 5, 2007 | 09:09 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
Re: new useage for a/c CONDENSER?????
I don't see why you can't but Tranny cooler kits a rather cheap and give you everything needed for the setup! I wouldn't if i were you.
Old Oct 5, 2007 | 12:15 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
dont think it would cause any problems seeing as its just a small radiator. i guess it would be a free alternative to buying a kit and its much larger. make sure you flush it out really good and let us know how it works... aslo its pretty big so you will probably need to add another quart of tranny fluid to it. make sure you put the intake line on the bottom that way it wont trap air.
Old Oct 5, 2007 | 06:00 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
1991, yes you can use it for a trans cooler. We used to use them years ago when we lived in the desert and could not afford a trans cooler. They worked well just make sure to clean it out before using it and make sure to blow it out with air before the install.
Old Oct 5, 2007 | 07:58 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
hey jim , you are spreading old hot rod stuff to new cars , and a new generation . ain't it great ??? i will be at CRUISN THE COAST tomorrow , lots of us old pharts , enjoying the rides . we will be having a south . ms. 3rd gen. get together , we hope to get more interest in third gens. .
Old Oct 5, 2007 | 08:09 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Hey UNCLE TOM, good to hear from another old phart. At some point when my health agrees I would like to get down your way and check out your ride. I am getting the Iroc ready for a run to Reno, highway 395 through Mammoth Mountain, the first of November, hopefully before the first snow. Take care, Jim
Bubbajones_ya
Jul 6, 2024 08:32 PM
jrdturbo
Mar 31, 2016 02:58 PM
my86bird
Oct 23, 2015 12:20 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
