Power Steering cooler
Old Oct 19, 2007 | 06:50 AM
Stephen's Avatar
Car: 87 GTA
My GTA has simple double tubes for cooling.
Would there be any benefit, to cutting the tubes, and running a finned cooler? Besides the cooling effect, you'd have increased capacity, itself providing cooling, as there would be more fluid, to disperse the heat.
Something like this?
Old Oct 19, 2007 | 05:18 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Power Steering cooler
ive got one like that on my car, its a little smaller though, i dont know if its helping things at all, cause i dont have a steering temp gauge, but its got to be better that the stock tubing cooler thingy.
Old Oct 23, 2007 | 11:30 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Yes, Do it its an easy upgrade.
My car would boil the fluid on track days with stock set up.
I added a transmission cooler like in your picture. Problem solved.
Add it to the return side not the high pressure side
Only drawback is be sure the lines are tight, double clamp if possible.
We have a cold day about once every five years in SC. Cold day is like 10 degrees. On one of these days I blew the lines off the cooler when I cranked the car up and turned the wheels which were frozen to the driveway. Had I waited for the fluid to warm up it would have been ok.
Other than that no problems.
Street car has 275/45/17 Toyo RA1 shaved tires and now only sees road racing track days. Cooler works great.
Old Oct 23, 2007 | 11:38 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have a 4x4 S10 that would boil the fluid off-road in 4 wheel drive. Found an aftermarket transmission cooler off some old truck/van. Gave like $5.00 for it. Got it home, flushed it with mineral spirits and water. Dryed with compressed air. Hooked it up. $5.00 autozone mounting kit. Problem solved.
Old Oct 23, 2007 | 11:47 PM
Stephen's Avatar
Car: 87 GTA
Well, here in central Texas, a cold day is in the high 20s/low 30s. If we get ice, it won't last past noon usually! LOL
How are you going differentiate between high & low side? There's only 1 outlet & 1 return inlet. With a simple tubing for a stock cooler.
I've got one off another GTA, just no pic of it yet. Simple tube cut, splice the cooler inline, right?
Old Oct 24, 2007 | 12:17 AM
SDIF's Avatar
Yes just splice it in like you said.
I meant don't splice between the pump to the box. The box to the pump is fine.
Just cut the line like you said.
Old Oct 24, 2007 | 06:49 AM
Stephen's Avatar
Car: 87 GTA
Ah....I was only thinking about the hard lines, not the rubber lines to the pump, Those are what you meant by high vs. low pressure.
Now I just need to find the one I was looking for. I'm betting Pep Blows has one. I hate using them for any service, their guys don't know squat, but off the shelf, its an OK place.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
