GN Fan Switch Part Number
Old Nov 18, 2007 | 08:28 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Anyone have the part number and source for a stock GN Fan Switch that's on @~220 & off ~200 degrees -- need to replace my Hypetech 4028 200/185 fan switch. I searched online & a store was selling the same cooling fan switch for 1987 305 Camaro as for the GN & want to avoid wasted time w/ wrong switch.
Old Nov 20, 2007 | 12:40 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Re: GN Fan Switch Part Number
Here's what I have in mine...
Brand: BWD part# TFS1 switch
Brand: BWD part# PT770 pigtail
I got it from Oreilly's, they had to get it from their warehouse. See if you can do some checking and make sure these are the temps you want, I've forgotten exactly what they are. Sorry it's not exactly what you need, but it's a start.
Old Nov 20, 2007 | 07:11 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Thanks - good price - specs weren't online so emailed - have to see what they say
Old Nov 21, 2007 | 03:28 PM
scooter500's Avatar
Car: 87 Camaro Z-28
think this is it - picture looks right - anyone have access to look up temperature operating specs for an ACDELCO part D1882D?
According ACDELCO site, this is a "SENSOR,ENG COOL TEMP" for a "V6 3.8L 231cid GAS FI T Engine VIN = 7" for following vehicles: FIREBIRD TRANS AM, FIREBIRD TRANS AM GTA SE, REGAL GRAND NATIONAL, REGAL LIMITED, REGAL GRAND NATIONAL, & REGAL T-TYPE.
Old Nov 26, 2007 | 09:48 PM
scooter500's Avatar
Car: 87 Camaro Z-28
update: read the Wells part catalog and found that SW505 has a 213-229 temp range, so am going w/ that one, plus only $8.99 at AZ. The part description for threads and picture are exactly the same as the list part (SW500). Hopefuly the SW505 lowers operating temp just enough but keeps it warm enough for a ccc setup.
The Wells catalog lists the SW500 as having a 220-239 temp range.
This info came from old posts with what looked like slightly lower cooling fan switch part numbers that may have worked w/ a single fan set-up like mine: GP Sorenson part number: FS6 - Opens at 220*- Closes at 204* F- Retail: Around $20, or a Standard Brands Ignition TS-136 220/204
I want to put a new fan control switch in this weekend at the same time I put in a new Stage 1 w/p & new balanced 195 thermostat.
Question -- Anybody have good or bad experience using one of these cooling fan switches in a single fan set-up?
Last edited by scooter500; Nov 28, 2007 at 07:46 PM. Reason: bought the right part and entered the specs
Old Dec 7, 2007 | 10:07 PM
the blur's Avatar
that buick fan switch is 203 on, 188 off. at least that is the information I have. I feel those temps are too cold for the winter...
The E motor switch in 1989 was slightly cooler than the F motor 1989 switch, which was 238F on,
The usual spread is 15 degree's.
Old Dec 8, 2007 | 05:53 AM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Read the sticky.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
