bad gauge hoepfully
Old Nov 27, 2007 | 02:44 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
bad gauge hoepfully
ok i just got an 87 trans am i think the guy before me did an engine swap cause its carbed not tpi. anyway. the temp gauge shoots up all the way. the car isnt overheating. but what sensor would cause a faulty reading on the gauge or is it just the gauge thats bad?
Old Nov 27, 2007 | 05:19 PM
Shotgun713's Avatar
Car: 1987 Pontiac T/A GTA
Engine: 350ci 5.7 liter
Transmission: Stock GTA Tranny
Re: bad gauge hoepfully
what motor are u talking about, Well 87 did have carbs on its v8, but it could be the sending unit for the guage it located on the driver side between cylnder 1 and 3 on both of my 87's(on my gta with the digital dash i first thought the gauge went bad b/c its digital but it turned out the clip on the sensor fell off so it was a simple fix for me)
Last edited by Shotgun713; Nov 27, 2007 at 05:21 PM. Reason: Didn't realize u were talking about a 6 cylnder lol
Old Nov 27, 2007 | 05:59 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
gotta be a sending unit i noticed today when i started it up the needle would jump from cold to hot extremes without cause. only thing i can think of is a faulty sending unit
Old Nov 27, 2007 | 06:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The temperature gauge sender is in the driver side head between the front two cylinders. You could try replacing it, but I'd probably try a new gauge.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
mike_c
Aug 27, 2015 04:32 PM
86IROC112
Aug 17, 2015 02:00 PM
