how does the cooling system pressurize?
Old Dec 27, 2007 | 10:58 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
what is the basic idea behind how the coolent is pressurized to flow through the engine?
Old Dec 27, 2007 | 11:26 AM
xbcrguy182x's Avatar
Re: how does the cooling system pressurize?
The water pump moves the coolant into the engine from the radiator. As the engine heats up, thats when the pressure gets built. Once the coolant is hot enough, the thermostat releases it back into the radiator for it to cool down. Its a cycle. In short, pressure gets built by the heating coolant and water pump moving it. If you dont have the radiator cap on, all that pressure gets released throught the cap hole.
Hope that helps.
9192camaro
16
Feb 3, 2019 12:21 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 26, 2015 04:59 PM
sreZ28
Aug 14, 2015 07:48 PM
