fan into shroud quest
Old Dec 29, 2007 | 07:00 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
how far soes the fan need to be into the shroud to cool properly? mines in just a lil bit and wondered if thatll work
Old Dec 29, 2007 | 07:30 PM
RazinCayne's Avatar
Car: 92 Z28 / 66 Biscayne
Engine: 355 / 427
Transmission: T5 / M22
Axle/Gears: 3.42 Posi / 3.73 Posi
Re: fan into shroud quest
Typically the fan is positioned inside the shroud with the blades width centered half inside and half outside.
Old Dec 29, 2007 | 07:48 PM
Engine: 355
does it matter if the blade isnt in half way? or will it just run hotter?
Old Dec 29, 2007 | 08:07 PM
RazinCayne's Avatar
Engine: 355 / 427
Depends on what fan blade your running. Some aftermarket fans are designed to pull alot of air. Do a simple test... Take a tissue and put it in front of your radiator. If it sticks you are probably pulling enough air to cool your motor.
Old Dec 29, 2007 | 08:11 PM
Engine: 355
im running the summit flex fan i put new puleys 3 groove to a 2 groove and i lost that extra legnth for fan
Old Jan 15, 2008 | 01:21 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
you can get a spacer to bring the fan farther into the shroud
Old Jan 15, 2008 | 02:01 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
You want to position the fan in the shroud as RazinCayne stated.If to far out you lose airflow thru the radiator/condensor(makes a noticeable difference if you have A/C.
sheachopper
Jul 31, 2019 11:27 AM
Reid Fleming
Oct 10, 2015 09:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
