Temperature gauge sender, and whats the one in the stat casting?
Old Apr 23, 2008 | 04:44 AM
andy625's Avatar
Car: Firebird 1987
Engine: 5.0
I intended to post this to find out where my temperature gauge sender unit is located, however I've just done a search and found that its on the drivers side of the head between cylinders 1 & 2. Is it easy to see from above, or is it burried around the header somewhere?
If the temp guage sender is on the side, then what is this sensor on the thernostat housing? My car is carbed '87.
Old Apr 23, 2008 | 05:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Temperature gauge sender, and whats the one in the stat casting?
The EFE valve, located between the pass side exhaust manifold and Y, is operated by a thermal vacuum switch (TVS) in the water neck.
Here's the answer to you other question (yours will look different):
https://www.thirdgen.org/forums/atta...cs-thermal.jpg
JamesC
Old Apr 23, 2008 | 07:08 AM
andy625's Avatar
Car: Firebird 1987
Engine: 5.0
JamesC
Thanks James, I changed the RAG joint over the winter (I've only just got the car back on the road after the salt season), I think I may have disturbed it while doing that. I'll check when I get home.
Thanks.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Nervous2
Oct 8, 2015 10:53 PM
Logan Bryant
Sep 23, 2015 06:51 AM
BWilcox
Sep 20, 2015 12:19 PM
CatmanFS
Sep 19, 2015 09:00 AM
