Overheating with 160 t-stat? wtf?
Old May 23, 2008 | 12:06 AM
whitroc's Avatar
Car: 1986 camaro Z28 iroc
Engine: lb9 topend 350short block
Axle/Gears: stock 10 bolt 3:23
my car when it was running(the one on my avitar to the left) would over heat when I started running it hard? like instantly. I would get maybe one good 50-90mph pull when I was racing on the freeway, then my car would run really hot and my power went way down. Any Ideas?
Old May 23, 2008 | 09:27 AM
xbcrguy182x's Avatar
Re: Overheating with 160 t-stat? wtf?
Basics....are your fans running? Is your air dam in place? What temperature is it hitting?
Old May 24, 2008 | 10:10 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
even more basic, check the coolant level.
Old May 25, 2008 | 11:28 AM
Drakon543's Avatar
Car: Camaro
Engine: TBI 305
Axle/Gears: stock
check your fluid lvl, make sure you get your system flushed get any of the junk that might be built up in it run it with the cap off to make sure it looks to be flowing properly if your thermostat is stuck shut it may not allow enough flow to keep it running cool also take a hose and if u can spray from your engine compartment out the front through your radiator to possibly clean out ne build up thats in there to help air flow
and as a reply to the well reply about your fans running my 91 rs has electric fans that the relay gave out on my way to tennesse (650 miles drive) and i lined up with a nissan 350z 120mph and no problems overheating it just couldn't sit in one place for long
Old Jun 4, 2008 | 02:29 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Mine did that when the head gasket was blown.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
