wiring both fans on
Old Jun 22, 2008 | 09:58 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
wiring both fans on
searched couldnt really find anything. The DS fan will come on when it should but the PS fan never comes on, all I want to do is wire it so when the DS fan would normally turn on, it turns on both fans. would it be as simple as just cutting the wires of the PS fan and splicing them to the DS fan wires?
Old Jun 22, 2008 | 10:32 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
Re: wiring both fans on
Yep, just splice and use connectors and then it will turn on when the other does.
Old Jul 4, 2008 | 05:46 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
If you want to control when the fans come on you can also splice into the green/white wire at each fan relay and connect a toggle switch to each one. I did this last year and still use the stock fan switch in case I forget to check the temp gauge. So far so good.
Old Jul 5, 2008 | 02:57 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
im going to leave the DS fan how it is and take the PS fan's power wire and run it to the ignition on the fuse box so it comes on when the car is running
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
