4th gen fan wiring?
Old Jun 27, 2008 | 08:53 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
4th gen fan wiring?
im looking to install dual fans from a 4th gen into my 85 iroc. curently i have my stock fan wired to a toggle via 30/40 amp relay. does anyone have a diagram for wiring the duals to a toggle? could a run them both off one 30/40 amp relay?
Old Jun 27, 2008 | 08:58 PM
Stephen's Avatar
Car: 87 GTA
Re: 4th gen fan wiring?
Use a DMM to see what the amperage pull is, per motor. If the pull, x2, is low enough for the realay you have, you should be good. Maybe not the BEST, but safe.
I'd rather have dual relays, on the odd chance one dies, one fan will stay working.
Old Jun 27, 2008 | 11:46 PM
Firebat's Avatar
You could just use 1 relay and wire then both up. 30 amps is quite a bit and one relay should be able to handle two fans. Its like over 400 watts in terms of power. I don't recommend a one relay setup though, I recommend temperature switches or computer controls to control the fans and this would mean running 2 or 3 relays.
I got 2 schematics for you. They are LT1 dual fan diagrams.
The top schematic works but having one fan turn on at low temperature at full speed. The 2nd fan can be turned on full fan speed at a higher temp.
The bottom schematic is a little better and uses three relays. It works by having both fans on at 1/2 speed at low temperature. This will make the primary fan last longer by not running it at full blast at low temp. It will also cool the radiator more evenly by having both fans on at low temp. At high temperature both fans will be on at full speed.
When the fans turn on depends on if you have temperature switches wired in, otherwise they could be wired to be on whenever you turn on a manual flip switch. Hardwiring them to a manual switch only might not be the best idea because having the fans run longer is going to shorten the fans' life.
P.S. - Summitracing sells a 10-pack package of 30A relays for $10. Too bad shipping is standard $10 but if you were buying other stuff with summit it would be a good idea to pick up some.
eightsixseven
Dec 16, 2024 01:50 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
