how can i delete a/c without loosing blower?
Old Jul 6, 2008 | 02:25 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
if this don't belong here mods please move it, i wanna delete the ac cuz it just plaint don't work pump is missing and it just takes up to much space ive got the cannister out both the rads are gone and all the lines everything associated with it but i need my heater can i just pull the box from a non ac maro? also theres a relay bolted to the box and what looks like a thermostat of some kind its got 3 springs on it can i delete either of these? if you dont know what im talking about just say and ill post pics p.s. i searched and couldn't find exactly what i was looking for
Old Jul 6, 2008 | 02:45 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: how can i delete a/c without loosing blower?
on my car, all i just took all of the components out (compressor, condenser, accumulator, all the lines) and left the AC blower on. that was about 3 years ago and everything still works great- the heater, vent, and defroster. i even kept the AC dash control panel, i just don't put it on the AC settings.
Old Jul 6, 2008 | 03:18 PM
Brennan's Avatar
that was the plan but that box is an eyesore and im gonna leave the control panel there anyway just cuz changeing it would be kinda pointless
Old Jul 6, 2008 | 06:30 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
The item you mention with the 3 coils is a resistor, this controls the speed for your blower fan, so You cannot remove that.
The relay box is used to offer the high speed fan, which is also good to keep since it allows you to keep your 4 speed fan control.
You can do like I did, remove all the AC stuff, and put on the motal box and fan from a non AC bird or camaro and then re-use the aforementioned AC speed control resistor in place of the non ac car's resistor, doing this allows you to keep your car's stock wiring.
I also recommend you use the non AC heater box's blower motor assembly instead of your car's AC blower motor and cage, it's a pain to fit the AC motor and cage to the non ac box (lots of swearing, cutting, more cutting, ETC) and the screw holes don't line up right.
It's really easy to do, I think there was even a post about the delete process that helped me, you might want to do a quick search for AC delete.
Old Jul 6, 2008 | 09:08 PM
Brennan's Avatar
ok im headed out to the junk yard in a few days to find the stuff anyway so i hope i can find a non ac camaro and i searched but i couldnt really find alot mostly just two or three posts ill try again with different wording tho
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
