Dual fan question
Old Jul 11, 2008 | 02:09 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Dual fan question
I know this is a seemingly simple ,maybe stupid question but on TPI cars with dual fans does one of them run constantly while the other comes on during a/c operation or when temps hit 220+? I converted my LO3 car to TPI but it still has the large single fan that never comes on since temps never get anywhere near that and the a/c has been long since removed. I've been considering changing the fan package but I'm wondering if it would be worth the effort.
Old Jul 11, 2008 | 02:23 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Dual fan question
One comes on with the temp switch in the head, the other when the ECM program tells it to.
The single fan comes on only with the temp switch in the right side head.
Old Jul 11, 2008 | 05:54 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I have the Flex O Lite setup for my 92 and it is a choice setup if you have the extra $$$. The unit comes with a seperate controller that allows you to setup what temps you want the fans to go on/off along with a toggle switch to manually turn the fans on/off
Frozer!!!
Jan 19, 2024 04:55 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
