Which way would you go
Old Jul 16, 2008 | 01:16 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
After much searching for information I'm getting ready again (never made it last time) to convert my single fan to a dual fan setup. The real question is which way do you think would be the best way to go of these three options taking into consideration ease of install, price, and most important, functionality:
1. Factory dual setup from a later model thirdgen (hooked up with both fans running off the single fan setup, with additional relays of course)
2. Factory dual fans from a 4th gen (same hookup as above)
3. On of these expensive jammies: http://cgi.ebay.com/ebaymotors/NEW-8...spagenameZWDVW
I read many posts but really am wondering if the original thirdgen setup running both fans at the same time will give enough cooling since it still doesn't really have any shrouds to speak of. If so I think I'd go that way as it's seems to be the easiest and cheapest way to go but I figured I'd get some other opinions before I start spending. I don't want to have to do this again.
Old Jul 16, 2008 | 01:18 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: Which way would you go
if it was me id do it the first or second way you would save a lot of money that way you can add even more to your car
