need help please
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
need help please
I did do a search for direction and did not find what I needed
I have stock dual fan setup on 350 TPI, I have an issue with cooling while cruising in city, found out however that the drivers side is rotating clockwise and the passenger is counter clockwise....
should they both run counter for a puller to work right, this happened after 305 to 350 swap.....and if so......
can I swap the wires to make rotate the opposite direction
thanks for all the help with the swap though
here's a pic of the motor
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
FANTASTIC
Yes they both need to pull thru the radiator.
Swap the leads on the offending fan.
Happy Racing!
-If people drove any slower
they’d be going backwards-
