Cyl.Head plug removal for fan switch
Old Aug 10, 2008 | 11:28 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Currently trying to remove plug in passenger side head between #6 and#8 cylinders for new fan switch. Any idea what size it is? Cannot insert 3/8" extension into it(too big) and 1/4" extension is too small. It has a square head opening. Any ideas on size befor I go look for tools?
Old Aug 10, 2008 | 07:53 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Re: Cyl.Head plug removal for fan switch
dunno,thought it was 3/8"?
Old Aug 10, 2008 | 08:30 PM
Zralou's Avatar
GM uses metric sizing. 3/8 would be around 10 / 11 mm.
Sara Lou
Old Aug 10, 2008 | 08:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Aug 11, 2008 | 04:29 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
I ground down a 3/8" extension to fit the plug. Now if I can only get it out. Have sprayed it with PB and letting it sit.
Old Aug 11, 2008 | 05:04 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
IIRC I bought a 10mm from snap on. Good luck to you, I tried to get mine out on the stock motor, and never got it out. I even gave it a shot while the motor was out, no luck. I hope you have more luck than I did.
Old Aug 14, 2008 | 09:56 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
They are hard to get out. In the past I have gotten them out with a chisel. I also have drilled out the center and used an easy out.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
TA8487
Aug 16, 2015 12:21 PM
3rdgenparts
Aug 8, 2015 07:09 PM
