Copper(brass) or aluminum
Old Aug 28, 2008 | 07:26 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
I need a new radiator. I see 2 types for sale. The aluminum single core, and the copper(brass) three core. Which will cool a 350/auto/A/C car better?
Old Aug 28, 2008 | 10:59 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Copper(brass) or aluminum
http://www.carolinarodshop.com/Store...in/griffin.htm
if you car is basically stock, either radiator is fine. if you get the griffen universal 31x19 with 1" tubes its a almost a direct fit, just need to move your heater return line to the water pump instead of to the radiator, and you can re-use your upper mount, you can't use the upper mount with the 1.25" tubes.
Linson
Oct 24, 2025 02:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
