Fan Control Switch Mounting Location
Old Sep 6, 2008 | 12:38 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
The owner before me wired both fans to come on when the key is in 'RUN' or 'ACC', and I wanted to fix that. I bought a Hayden kit that comes with a temp probe/switch that mounts in between the radiator fins and turns on @ 185* and off at 160*. I hooked everything up and included a manual override switch. Went to test it, and the manual override works fine but the switch never kicked in. The temp gauge climbed to 220+* and nothing happened. I verified the gauge with WinALDL, and it is correct. I verified the switch works by holding a torch under it and measuring the voltage across - when heated, it closes; when cooled, it opens. I then relocated the probe/switch to a T-fitting in a radiator hose, hoping that would trigger the switch sooner, but no luck. So where is the best place to mount these things?
Old Sep 6, 2008 | 12:52 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Fan Control Switch Mounting Location
Doesn't it have a small metal dial that you can turn, like a house thermostat so you can "dial" in when you want the fans to switch on? I put my probe on the top of the bottom radiator hose.
Old Sep 6, 2008 | 12:56 PM
87GTAj's Avatar
Engine: 5.7L TPI
No, it's not adjustable. Just a thermal switch with preset on/off points. Your probe is just sitting on top of the hose, not inside and it works fine?
Old Sep 6, 2008 | 01:16 PM
Kevin84Z28's Avatar
Yeah, I didn't like it shoved in the fins of the radiator so I just zip tied it to the top of the bottom radiator hose.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
TA8487
Aug 16, 2015 12:21 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
