Overheating
Old Oct 30, 2008 | 12:14 AM
IrocZTPI's Avatar
Car: 1990 Camaro Iroc Z
Engine: 5.7L TPI
Overheating
I am having a problem with my 90 Iroc overheating i have checked the fans, replaced the water pump, tryed many thermostats, replaced top radiator hose, lower hose in good condition, and the air dam is new and the radiator was replaced six months be fore i bought it.
Old Oct 30, 2008 | 12:31 AM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: Overheating
i know i was told that the third gen cars in an attempt to complete the burn better will run up to an extremely high temperature which it will cool back down run back up and down untill you are moving again, mine running down the interstate prob. never leaves about 180 but setting still it runs almost up to 230 for just a few and then back down over and over setting in the jack in the box drive through, freaked me out the first time i saw it, like you i ran for the thermostat, the fans, the radiator hoses, the water pump,radiator cap and everything i could put on it to keep it running cool but it never worked, ive heard that you can buy a lower degree thermostat which will cut the fans on earlier but you can go to advance for the same price and get and adjustable one which you can set to your own preference its an electric fan on your car im guessing so your already 1/2 way there.
Old Oct 30, 2008 | 12:44 AM
IrocZTPI's Avatar
Engine: 5.7L TPI
Re: Overheating
it has electric fans but the guy i bought it from wired them into a switch
Old Nov 19, 2008 | 12:26 AM
dfarah@live.com's Avatar
Re: Overheating
Iroc rocks.
Old Nov 19, 2008 | 01:36 AM
allenfre's Avatar
Re: Overheating
Hmm... How hot was it? I would suggest to atleast try installing a manual fan switch it can help you in a little way. I need to know every details first man thanks.
Old Nov 19, 2008 | 04:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Overheating
You might check the lower hose, which should have a spring in it to prevent collapse.
JamesC
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
