Power steering cooler mod for cheap
Old Nov 6, 2008 | 01:08 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
in order to get my griffin radiator to fit, i had to remove the stock cooler lines, the ones that run along the bottom of the radiator. interesting enough i was able to fit a tube and fin cooler from a 4th gen honda prelude in the stock location, it even lined up perfectly to the stock mounting location, and i used the same bolts. so i thought i would make a post and tell people about a simple mod, and im sure it cools better than the stock lines because it has the cooling fins on it.
what you need to find is a 92-95 honda prelude, its a U-shaped tube that is mounted in front of the condenser.
Old Nov 6, 2008 | 05:18 AM
kcb37's Avatar
Re: Power steering cooler mod for cheap
Looks good,
sometimes creativity is a good thing.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
mustangman65_79
Aug 9, 2015 03:00 AM
