heat only blowing from defrost vents
Old Nov 21, 2008 | 05:35 PM
bph270's Avatar
Car: 1984 camaro
Engine: 355 sbc mildly built
Transmission: th350 w/shift kit and megashifter
Axle/Gears: 272 posi borg warner
hey guys i have a 84 z28 and i just dropped in a 350. when i turn the heater on it only blows from defrost. i've learned it switches off vacuum. which vacuum hose do i need to hook up and to wear? thanks
Old Nov 21, 2008 | 06:08 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: heat only blowing from defrost vents
There should be a hard plastic vacuum line on the firewall near the HVAC box. hook it to manifold vacuum, that should do it.
Old Nov 21, 2008 | 08:19 PM
bph270's Avatar
Car: 1984 camaro
thanks i just went out and tried that one. it works great now. thanks
Old Jun 14, 2009 | 08:31 PM
2LTCamaro's Avatar
sorry to bring this topic back up. I am having this same problem, are you talking about where the big thick set of wires comes through the firewall and there are 2 really small hard plastic lines coming in? One goes to the bypass(which I removed) and one goes to the back of the throttle body? I need help, only my defrost works. Also the cruise doesn't work, could these be connected?
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
mfp189
Sep 27, 2015 09:25 AM
