RADIATOR COOLING DUCTS
Old Nov 26, 2008 | 11:23 AM
JOHNB5000's Avatar
HAS ANYONE EVER SEEN OR DO YOU POSSIBLY HAVE SOME INFORMATION ABOUT RADIATOR COOLING DUCTS THAT ARE SUPPOSED TO BE INSTALLED BETWEEN THE FRONT BUMBER AND THE RADIATOR CORE SUPPORT ON AN IROC?
I HAVE NEVER PERSONALLY SEEN THESE INSTALLED ON ANYONES CAR.
Old Dec 1, 2008 | 04:45 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
BE COOOOOOOLL ! ! ! !
Your best bet would be to contact a racecar builder.
The setup you want is similar to a road racing setup.
Happy Racing!
- Race clean! Do it on dirt! -
Old Dec 1, 2008 | 05:15 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: RADIATOR COOLING DUCTS
I've got them on mine.
Have seen them on alot of other 3rd gens.
When I get a chance will take pic of them.
Have to take pic from back as grille in place where
my fogs used to be.
Later
Old Dec 2, 2008 | 06:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yep, got'em on my 85 IROC. I noticed a few years ago that one was cracked so I went to the dealership where the counterman told me they didn't exist! I ended up scavenging them from an 88 RS, IIRC.
JamesC
Old Dec 3, 2008 | 10:32 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
PICS?
Old Dec 3, 2008 | 10:37 AM
JamesC's Avatar
Bad, look directly behind the fog lights on your IROCs and you'll see the ducts--they can also seen from directly above if the filler panel (around the hood latch) is removed.
JamesC
Old Dec 9, 2008 | 08:35 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
i took them out of two of my cars, never had any overheating problems. they needed to come out for the ram air boxes i made. only benefit i see from them is less chance of the air coming thru the fog light holes being sucked underneath the radiator rather than thru it, seems as though the air dam does a good enough job to not need the ducts.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
