toggle switch for coolant fans
Subscribe
Jan 4, 2009 | 06:09 PM
i need instructions on how to wire a toggle switch to my coolant fans either primary or secondary.
Reply 0
Jan 4, 2009 | 06:14 PM
Re: toggle switch for coolant fans
if i rember correct their is a geen wire with a white strip on your fan realy you tap into that and ground it out through the switch. i belive that you can do both the green wires and ground out both of them to work keep both fans on
Reply 0
Jan 4, 2009 | 06:31 PM
so tap into the grn and white wire going into the relay or coming out of the relay?
Reply 0
Jan 5, 2009 | 07:12 AM
Welcome to TGO. The sticky at the top of the page may prove helpful. BTW, a search is always a good idea.
JamesC
Reply 0
Subscribe
