Heater not working right
Old Jan 9, 2009 | 10:26 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
The heater in my car is not working like it should. The heat seems to only be coming out of the defrost vents, and even on high, hardly any air is coming out at all. I swapped the car over to the a/c delete so I dont know if something happened with that or not. What are some things that I should look into?
Old Jan 11, 2009 | 03:37 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Heater not working right
Could anyone tell me where the vacuum line for the HVAC ends up going to in the interior?
Old Jan 11, 2009 | 04:14 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Are you sure that the top leaver is set on "vent" and not on anything other.
-Edit-
Should be set up like the picture below except you most likely want the fan on high and not low
Old Jan 12, 2009 | 08:32 AM
creese187's Avatar
that goes behind the climate control switches
Old Jan 12, 2009 | 01:29 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yeah, it will only come out of the defrost setting though.
Old Jan 12, 2009 | 02:18 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You have a vacume leak. I would start looking for the leak behind the controls, but it could be under the hood. This has been covered before, do a search if you need more info.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
