good pusher fan?
Old Feb 10, 2009 | 09:16 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
good pusher fan?
What's a good pusher fan model number that will fit nicely in a stock set-up?
Today my single 16" worked just like it should. I've replaced parts along the way. but there's that trust facto, and with the summer up ahead I want to add a back-up pusher fan.
Old Feb 10, 2009 | 10:33 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: good pusher fan?
Would have to be pretty thin to fit between the x-brace
and the A/C condenser-i think a thin type 12" flex-a-
lite would fit if the shroud was trimmed just a bit.
The problem with pusher fans is they are about 40
percent less effective than the exact same fan properly
mounted behind the radiator/condenser,the reason is
the air on the discharge side of a propeller fan is
rotating like a vortex and the air hits the radiator fins
at an angle,reducing airflow. if overheating is experienced when the weather gets hot,a higher power
puller fan would be better-HD fiero/buick grand nat.
type,ford taurus 2spd,or '87 up 3rd gen dual fan with
both fans wired to come on at the same time.
Old Feb 11, 2009 | 08:25 PM
scooter500's Avatar
Car: 87 Camaro Z-28
ok, good thoughts
Old Feb 15, 2009 | 02:15 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Also, generally not advised to mount a pusher directly in front of a puller, as they will offset eachother and compound the situation. Blowing air into a fan that's already pulling air doesn't really work. If you want reassurance, just get a puller with a higher CFM rating.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
TA8487
Aug 16, 2015 12:21 PM
