Help!!!! effects of my coolant flush
Old Mar 29, 2009 | 04:24 PM
baconboy's Avatar
I just did a coolant flush on my 87 trans am. it was fine before but it was really really dirty. i let all the old dirty coolant out and then ran a hose through it to clean it out as much as possible. after that i plugged it back up and put brand new coolant and water back in it. now its having trouble starting, not only that but the temp gauge is freaking out. does anyone know what i did wrong and what can be done to fix it???
Old Mar 29, 2009 | 07:40 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Help!!!! effects of my coolant flush
Sounds like you have air in the system.
With the engine cool (cold is better) remove the radiator cap and top off the radiator.
Start the engine and top off the radiator as needed.
Set the HVAC temp to HOT. Turn the blower on to high.
Let the engine come up to operating temperature and let the fans cycle a few times.
Top off the radiator and replace the cap.
Fill the reservoir to full.
Shut off engine. Done.
Old Mar 29, 2009 | 07:44 PM
Burgundy Bomber's Avatar
Car: 84 Z-28, 01.5 Cummins 3500, 98 Ford
Engine: mild 355, built Turbo Diesel
Transmission: th-350
Axle/Gears: soon to be broken, 3.55's in diesel
Good advice.
if it was too nasty you may not have gotten it all the way clean (not saying that has anything to do with your problem just saying...), i always ran vinegar in mine, let em get hot, then cool down and hose it out, it's a long stinky process with good results though. let us know if you take care of her.
Old Mar 30, 2009 | 04:40 AM
baconboy's Avatar
there might be a problem with that... lol the heater doesnt work in my car yet... i just bought it and thought a clean radiator is more needed than a heater at the moment. is it absolutely vital i need it to help or can i do it without it?
Old Mar 30, 2009 | 09:02 AM
kcb37's Avatar
Is the fan bad?
The reason you turn the heat on is because you have a valve that opens and closes. This lets coolant flow to the heater core. Even if the fan dosen't work turn the heat on. It will still let coolant in. That will get all the air out of those two hoses and the heater core.
Or if you want until you get the heater fixed, you can take the hoses off the heater core and loop them to the engine.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
