Would these components keep me cool?
Old Apr 19, 2009 | 11:35 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I want it under 200* at all times. Would these things put me there?
180* T-Stat http://store.summitracing.com/partde...8&autoview=sku
200* on, 185* off Fan Switch http://store.summitracing.com/partde...5&autoview=sku
My engine runs 220* all day long now, so nothing is mechanically wrong to make it run hot.
I also need help with crossing some wires so both my fans come on at the same time.
Old Apr 20, 2009 | 04:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Would these components keep me cool?
that would be a good setup, though it will probably go about 200 a little bit now and again depending on hot warm it is outside.
If you haven't already, i would upgrade you radiator and leave the fans alone.
Old Apr 20, 2009 | 06:32 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Thanks 86. A little over 200* wouldn't be bad once in a while i guess, 220+ is just too hot for me. My radiator should be good (keyword should) i just want both my fans to turn on at the same time. I took the A/C off so the second fan doesn't come on at all. I've got time, my car will be in paint for a good 3-4 weeks yet.
Old Apr 20, 2009 | 06:42 PM
carzwitballz's Avatar
Car: 91 Camaro RS/2005 Dodge 1500 4X4
Engine: 305/ 5.7 HEMI
Just a thought...There is a product made by redline called water wetter...it works great..only thing is you run it with only water...
Old Apr 20, 2009 | 07:05 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
my buddy uses water wetter in his sled WITH coolant, no problems. he says the stuff works great.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Briandrex
Oct 5, 2015 06:20 AM
