non functional fans or compressor when A/c is on
Old May 22, 2009 | 11:53 AM
Tanaman's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L
Axle/Gears: 3:73
Looking for some help with my GTA. I have the electricly controled heater-A/C and when I turn on the A/C the neither the cooling fan or compressor turn on. The fan relay is new and the fuse is good but I am unsure what to check next. Even if the A/C system was empty wouldn't the fan come on anyway? I really want to get the A/C working again as the interior gets too hot to enjoy driving the car when it gets hot out.
Thanks in advance for any help given.
Kurt.
Old May 26, 2009 | 12:36 AM
Rockguy's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Re: non functional fans or compressor when A/c is on
You have the dual fans right? I assume the driver one works when the car is hot enough but, the passenger side isn't working? If so, I don't think it will come on if you are way low on refrigerant. I wouldn't replace any expensive parts til you charge that A/C up
Old May 26, 2009 | 12:36 PM
Tanaman's Avatar
Engine: 5.7L
Axle/Gears: 3:73
Thanks, I suspected that the A/C fan might not come on if I was low on R12 but I was not sure if it would come on anyway. I am going see if anyone around here is able to recharge it with R12 next week.
Thanks again,
Kurt.
junior419
Apr 7, 2025 11:35 AM
codeysabatini
Nov 10, 2015 04:07 PM
my86bird
Oct 23, 2015 12:20 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
