Bad Fan Switch??
Car: 1991 Z28
Engine: 5.7 v8
Transmission: Automatic
Bad Fan Switch??
my fans only turn on when i turn the a/c on. is it the fan switch causing that? and is the fan switch on passenger side on the 350 engine?
I could use some help.
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: Bad Fan Switch??
Okay. The fan if u have duals. The one fan will turn on if you have a/c on. the other one will only turn on when the engine gets hot by the fan switch. That could be the colprit if the secondary fan not working.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Pull the lead off the switch and ground it with the ignition in 'run'. If the fan comes on you'll know the relay and wiring are good. The fan switch itself is unlikely to go bad. It may just not be getting hot enough.
Car: 1991 Z28
Engine: 5.7 v8
yea thats what its supposed to do. but when i turn the a/c on they both kick on. even when i just start the car
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
It's probably the fan relay thats bad. Usually if the fans work only when you turn on the a/c its because it bypasses the relay. If the relay is bad they wont turn on, only when u run the a/c.
There's a relay for each fan if you have duals. The AC switch, temp switch and ECM all provide a ground to relay to engage the fan(s).
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
eightsixseven
Dec 16, 2024 01:50 PM
86IROC112
Aug 17, 2015 02:00 PM
TA8487
Aug 16, 2015 12:21 PM
