deleting A/C
Old Jun 9, 2009 | 03:23 PM
Canadianguy2006's Avatar
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
deleting A/C
ok i have done a search, and haven't found any A/C removal instructions, nothing specific anyway, does anyone have any pics of removal or step by step instructions? i do have the delete pulley and the box is on the way
thx
Old Jun 9, 2009 | 04:05 PM
Smoke_Jaguar's Avatar
Car: 1986 Camaro T-Top
Engine: 2.8L V6 (MPFI)
Transmission: 5 Speed
Re: deleting A/C
A/C removal is pretty basic, removing things like the evaporator might be a bit of a pain and there may be a difference with the radiator mounting once you remove the condensor as well. The process will be relatively similar with most cars in general and an A/C system is not entirely complex. In general, you have 6 general things to remove, lines, compressor, evaporator, accumulator, wiring (to the compressor clutch) and in some cases the compressor bracket (check the belt routing of a non A/C version, might not need a bypass pulley). Also, if the system is still pressurized, might want into having it evacuated at a shop so you don't vent the refrigerant to atmosphere (illegal in a lot of places).
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
