92 camaro blower motor hardly puts out air
Old Jun 20, 2009 | 06:57 PM
gomez101380's Avatar
Car: 1992 RS
Engine: 305 T.B.I.
All right where to began I have read alot of threads and have done just about all of the things talked about still same thing. Hardly any air movement in every speed lower speeds are worse. I have tested relay, resitior, motor. Went ahead and put a new blower in while I had it out cleaned as much of the coil as i could. Made a jumper hooked the blower right to the battery same thing. Also pulled the screen and used the vaccum down there as well. Relaced the gm screw up with heavy duty con. Anybody have an idea where to go next. I sure could use the help
Old Jun 21, 2009 | 10:41 AM
Car: 1992 RS
Engine: 305 T.B.I.
Re: 92 camaro blower motor hardly puts out air
Any help would greatly appreciated Thanks
Old Jun 21, 2009 | 11:22 AM
WaltB_FB92's Avatar
Car: Pontiac Firebird
Engine: V-8 305
Transmission: Automatic 4-speed
Axle/Gears: non posi
Check to see if the motor is turning in the correct direction, there is a arrow printed
on some of the new blower fans if it was wired incorrectly then the motor will pull
rather then blow air. If that doesn't work check to see if it's locked up. You may
have to drill to inlarge the hole in the left upper bracket bolt, then shift the blower
motor to the right about a 1/4 inch this should free it up. Feel the input wires if
they are hot to the touch then it's locked up. Adjust from there with a larger hole.
I had a similar problem with a Canadian blower and the holes set at the factory may
be out off specification.
Old Jun 21, 2009 | 01:00 PM
Car: 1992 RS
Engine: 305 T.B.I.
Blower turns in the right direction just no volume out the vents. Far as making sure it works its new. I had the same problem with the holes not lining up. Is there a possibility that I have restrication in the air box. When I had the blower out I cleaned out all the debris that i could.
Old Jun 21, 2009 | 03:11 PM
WaltB_FB92's Avatar
Engine: V-8 305
If you replaced the cage confirm that the balance weights are on
and that it has the correct angle as with the one that was replaced.
Some cages are for car's without AC systems.
Old Jun 21, 2009 | 05:25 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
How clean does the air smell? Think your evaporator could be gummed up with crud?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Zachattack0925
Aug 12, 2015 09:52 PM
