A/C blows out hot. Need freon?
Old Jul 18, 2009 | 05:35 PM
beaus 89 camaro's Avatar
Car: 1989 pontiac firebired
Engine: 2.8 fuel injected v.6
When I turn on my a/c it only blows out hot air. Do you think the freon needs to be charged? What could cause this?
Old Jul 20, 2009 | 08:00 AM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
Re: A/C blows out hot. Need freon?
it depends on how hot, if its warm then it just needs freon, but if its hot then make sure the car aint overheating.
Old Jul 21, 2009 | 08:31 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
AIR REPAIR
Make sure the blend door is functioning.
With the controls set to the AC position see if the compressor is turning.
Then see if the radiator fan is turning.
If they are, use a set of gages to measure the pressures in the system.
If it’s low add refrigerant and check for leaks.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
jrdturbo
Mar 31, 2016 02:58 PM
blackz281le
Jan 11, 2016 07:51 AM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
