white deposits in rad
Old Aug 23, 2009 | 01:07 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Just bought a Camaro, the rad is completely dry and there is flaky white deposits on the metal inside. It similar to calcium buildup. Flakes off to the touch for the most part. Has anyone seen this before? I did a search but couldn't find anything... would a flush get rid of this crud?
Old Aug 23, 2009 | 02:35 AM
z28 TPI's Avatar
Car: '85 Camaro Z28, '90 300zx
Engine: 350 4 bolt main TPI
Transmission: 700 r4 automatic
Axle/Gears: ? not there yet, i know its stock
Re: white deposits in rad
You could try it I think its just an alkali build-up though. Just run the flush and see. You probably dont want to run anything to caustic cause it will run though the engine. The flush should be cool.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
89bird2.8
Sep 25, 2015 09:21 AM
Stryker412
Sep 20, 2015 06:59 PM
