I have a real puzzel on my hands.
Old Sep 28, 2009 | 04:11 PM
tgk7203's Avatar
I am losing coolant and I cant find were it is leaking. I wasnt having any problems before replacing the belt tenchiner. There are no visable leaks but on a two hour drive the over flow bottle is empty. Maybe a preassure test I dont know. But with hood up and car running still see now leaks cheaking everywere I can see and even lloking at the block I no smoke either. Please help thanks for looking
Old Sep 28, 2009 | 04:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: I have a real puzzel on my hands.
Are you checking the radiator, or just the overflo bottle? When it cools, check the radiator, fill it, and thrn top off the overflo bottle to the cold mark. If there is air in the system, as it dissipates the pressurized system will suck extra coolant needed from the overflo bottle - maybe you just are a little low. The level will vary in the overflo bottle as well, depending on the pressure in the system.
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
