Fan Troubles
Old Oct 8, 2009 | 03:22 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Transmission: 700 R4
Fan Troubles
Hey guys having some trouble with my fans. Got the car with no engine installed and just put one in and the fans will not kick on. They will not turn on when the blower or AC is turned on. I ran it almost up until it got into red on the gauge. The only way they will kick on is if the car is in diagnostic mode when I check for engine codes. I have replaced the passenger coolent sensor in the head. The other two sensors looked ok. The car is a 89 L98.
Mike
Old Oct 8, 2009 | 04:37 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: Fan Troubles
did you check the relay dude... mine was doing to same thing... turned out to be a blown fuse going to the relay.. made me feel like an idoit but i just most of a new system out of it... lol
Old Oct 8, 2009 | 05:56 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Re: Fan Troubles
That was the first thing I did was check the fuses and all checked ok. Could it be a relay? If so which relay is it, the one behind the passenger side headlight?
Old Oct 10, 2009 | 09:15 AM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Re: Fan Troubles
I'm curious to know which relay it is...
sheachopper
Jul 31, 2019 11:27 AM
mrbird
Oct 20, 2015 03:43 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Lmancha96
Sep 25, 2015 08:11 PM
