cooling trouble
Old Nov 19, 2009 | 02:44 PM
FloridaZeke's Avatar
Car: 89 Firebird
Engine: 305 TBI
Transmission: 700r4 I think
Axle/Gears: not sure
cooling trouble
Got an 89 firebird formula a couple weeks ago...305 tbi with a six year old jasper in it...I thought it seemed to run a little hot so I put a new thermostat in it..elect fan is coming on and off intermittently looks like around 220 and off about 190 or so based on the 20 year old gauge and brings the temp down some but the first time I took it out on open road where I could open the engine up some the temp needle started to climb considerably...when i stopped (eng still running) the fan cranks and the temp comes back down????
I can see there is good circulation from the water pump...
cap looks new and pull the lever you can hear press release...
strange...this car deserves to be opened up on the freeway....
any help would be appreciated...
Old Nov 19, 2009 | 04:08 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: cooling trouble
go look up under the front of the car and see if the air dam is still there.
Old Nov 19, 2009 | 04:19 PM
Car: 89 Firebird
Engine: 305 TBI
Re: cooling trouble
if you mean the front spoiler it appears missing...I see bolt holes underneath...
could that make enough difference?
if so wonder where I could get one?
thanks
Old Nov 21, 2009 | 09:53 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: cooling trouble
you can order them from several people here online. i think thirdgenranch has one.
Old Nov 21, 2009 | 03:27 PM
Checkerbelly's Avatar
Re: cooling trouble
I've heard the air dam can make a pretty big difference.
What do you mean you could see that the water pump was circulating water? I want to check on my water pump but I'm not sure how. Thanks and good luck.
Old Nov 21, 2009 | 03:49 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: cooling trouble
the front airdam i am reffering to mounts under the car on the bottom of the radiator mounting bracket. it creates a low pressure area so air will go in the radiator.
remove the radiator cap and see if coolant is flowing with the car running. if it is hot wait till it is warming up with the cap off.
Old Nov 22, 2009 | 09:41 AM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: cooling trouble
https://www.thirdgen.org/forums/cool...deflector.html
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
mrbird
Oct 20, 2015 03:43 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Lmancha96
Sep 25, 2015 08:11 PM
