91 rs overheated
Old Jan 2, 2010 | 10:41 PM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
91 rs overheated
i got a 91 rs 305 tbi/ so today(rather cold day barley got above freezing) the car started to over heat after a 15 min drive. i didnt think much of it since it didnt go too high and i didnt let it warm up. 5 hours later i start the car up let it heat up for 10 min and drive it home. so after 15 min of driving it gets into red and lucky i just arrived home. i turn the car off and the resivor is bubbling with coolant. i wanted for car to cool down checked radiator and it was full theresivor was too. so could this be the thermostat or somthing bigger?
Old Jan 2, 2010 | 10:58 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: 91 rs overheated
Off the top of my head....bad thermostat, bad water pump, plugged radiator or your fan isn't kicking on. Check your fuses/relay for the fan and make sure it's turning on then go from there. Water pumps usually let go with no warning.
Old Jan 3, 2010 | 02:36 PM
one92rs's Avatar
Car: SOLD!!!!!
i would make sure there is enough coolant. in a climate that cold it is not circulating coolant. also look at the thermostat. heck man replace it there cheap.
Old Jan 3, 2010 | 03:22 PM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
yea it was the thermostat i just wanted to make sure tht was the problem it runs fine now tho tnx for the help
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
