electric fan switch probe vs thermo
Old Feb 14, 2010 | 03:57 AM
techno_1961's Avatar
ok so i bought my first camaro its a iroc-z with a 305 tune port injection the person who had it before me hacked the wiring up for the electric fan it turns on with the ignition and stays on . my question is some cars have a thermo sensor hookup where it activates the fan and it hooks up to the block. but they make a radiator probe type fan switch thats adjustable meaning i can set the deg. that i want the fAN to turn on. http://www.summitracing.com/parts/HDA-3647/ is this going to work ok? im going to have the shop at the end of my road hook it up. its a 1986 iroc
Old Feb 14, 2010 | 10:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: electric fan switch probe vs thermo
That should work. Maybe pricier than figuring out what's wrong with the stock setup though.
Old Feb 14, 2010 | 12:50 PM
bitchin86's Avatar
Car: 1986 iroc-z
Engine: lt1 intake 406
Axle/Gears: stock 89 gta 10 bolt 3.42 non posi
autozone carrys the probe ones and i think they are a little cheaper too.
i know alot of people running them and they work awsome!
Old Feb 14, 2010 | 02:20 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Pepboys has them too. The cheapest is about $18, but they didn't have it when I was there
Old Feb 14, 2010 | 04:25 PM
thanks guys i ordered the probe type
Old Feb 18, 2010 | 11:16 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Just chiming in too. I have the probe-type in my IROC, and it works great.
Old Feb 18, 2010 | 11:30 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i once had to add a thermostat control to an'89 firebird
2.8 after someone fubared the original setup-used a
flex-a-lite thermostat control with sensing bulb and
capillary tube,removed the upper radiator hose,stuck
the sensing bulb into the hose,reinstalled the hose with
a little silicone to seal around the capillary tube,
connected switch to repaired wiring,and set fan turn on
temp.Simple,reliable,and adjustable-fixed!
Old Mar 7, 2010 | 02:39 PM
kingzrt's Avatar
Car: 1987 IROC-Z
Engine: 5.0 305ci 4 barrel Edelbrock carb
where did you install the probe? Where in the radiator, top, middle? i have same problem wiring hacked and have spent days searching for the wires.
Old Mar 10, 2010 | 07:57 PM
erc07's Avatar
Car: 87' IROC-Z
Transmission: Automatic
hey im also having alot of trouble with my fans. can yall elaborate more on how these fan switches work? and the pros and cons? i also own a 87, 305 5.0 iroc
Old Mar 11, 2010 | 08:28 AM
kingzrt's Avatar
Car: 1987 IROC-Z
I have spent 3 days under the hood of my 87 IROC. Here is what i found out hope it helps. 1st the cooling fan runs on a sensor in the engine, it sends a signal to the ECM which in turn starts the fan, (Cooling fan)I was under the impression that the water temp sensor and the sensor for the fan were one in the same but they are not. There are 2 sensors. If you are TPI One is in the engine block drivers side or passenger side depending on the engine. The one that sends signal through the ECM is right side if TPI intake near cold start sensor etc, 2 wire i believe black and yellow wires.
The 2nd fan A/C should come on when a/c is turned on, that is done through the pressure switches. Mine had 2 pressure switches one on back of compressor and one on right side runs along the cooling/heater hoses.
I can not get my 2nd fan to come on with the A/C so i have more trouble shooting to do. I also do not have anywhere near original equipment engine is a 327 with Carb intake, i have my hands full with this but i want the car to be operating as close to original as possible.
Hope this helps
Hotrodboba400
Dec 10, 2019 07:07 PM
luvofjah
Sep 3, 2015 07:08 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
