Coolant Diverter valve with carb?
Old Mar 19, 2010 | 04:48 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
Does this valve work with a carb? I was at the JY yesterday and saw one so I grabbed it. I was wondering if the feed from the plenum could be replaced by the feed from the intake manifold. I didn't know if there is a pressure difference. My vacuum lines were just cut at the firewall. Also if so, how do you know which vacuum line should go to the diverter valve? And the vacuum line to engine vacuum, where should that be tied in? Any help would be appreciated as I'm putting in a new heater core this weekend and need to plumb everything. The heat was eliminated on the car when I bought it.
Attached Thumbnails Coolant Diverter valve with carb?-coolant-hose-diagram.jpg
Old Mar 22, 2010 | 12:39 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: Coolant Diverter valve with carb?
Engine vacuum will go to the heater controls and the vacuum line from the heater control goes to that valve. You can block off the part that goes to the throttle body, thats just there to prevent throttle icing.
gta90
Sep 15, 2015 04:00 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
cstrobel65
Aug 15, 2015 10:19 AM
