dual fan wiring
Old Mar 19, 2010 | 04:13 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
dual fan wiring
Hey guys.. after searching through my manual and online, I can't seem to find any clear answers or wiring diagram. Here is my problem;
'91 Z28 5.7 TPI - previous owner wired the dual fans to be on at all times with the ignition key. That was probably a good idea being an original Florida car, but now that I've got it in Canada its not always the best idea.
I'd like to return the dual fans to 'stock' operation, but I don't know where to look or how it should be normally. Now I know it should be fairly obvious where the connections were severed and connected, but there is a lot of questionable connections and black tape under the hood.. the more I look at it, the more I'm surprised everything works.. lol.
So any help is appreciated on ideas on where to locate this wiring mod and a clear wiring diagram would be a big help.
Thanks!
Old Mar 21, 2010 | 07:08 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
Re: dual fan wiring
They probably wired it by cutting into the "+12v in run" wire feeding the fan relays. Start by tracing the wires back from the fans to the relays and see if that is what they did. My single fan, the second was removed, was done this way and this is how I got it back to normal without the TPI. If you are still using the ECM, your coolant fan switch wire should be connected back to the ecm as well. Here is how I fixed mine.
https://www.thirdgen.org/forums/elec...ng-please.html
Old Mar 21, 2010 | 08:34 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: dual fan wiring
Take a look at " ******* updated Total Fan Control " if you haven't seen it yet.
It's the last sticky under -- Cooling -- threads.
Good info!!
( IDK why I can't get the link to post up from my iPhone. )
Old Mar 25, 2010 | 07:18 PM
Brisk's Avatar
Re: dual fan wiring
good info here guys.. I'll have to read through both threads and find some time to get under the hood again. thanks for the links!
Old Mar 25, 2010 | 08:23 PM
Car: '87 Camaro
Re: dual fan wiring
Brisk--
sorry it took sooo long--
https://www.thirdgen.org/forums/cool...al-fan.hotmail
Is this going to be any help??
Good luck!!
Old Mar 26, 2010 | 10:02 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: dual fan wiring
Signature has some diagrams.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
