water in oil
Car: 92 b4c rs camaro
Engine: tpi 350
Transmission: mad dog 700r4
Axle/Gears: 3.77 posi
water in oil
I have a 92 350 tpi with cast iron heads, been building this car for 2 years finally got it on the road and during the shake down run looked in the rear view and saw the worst thing ever, smoke billowing from out of the back of the car. when I got the hood up the dip stick was pushed out and oil every where. found there was water in the oil. once we got it down to the shop. checked the oil adapter, and pressure tested the cooling system. it seems to be holding pressure, but looses about a half pound per hour. any suggestions. also car still runs great, suggesting the head gasket isint blown
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: water in oil
if its coming out the tail pipes, the water is getting into the cylinders. It could be a intake manifold gasket, but would seem to be a head gasket or crack in the head or block.
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Re: water in oil
Did you use thread sealant on the head bolts? Look under the valve covers for signs of water. Improper sealing around the water passages at the intake manifold could also cause a weak leak that gets stronger as things expand, also double check the torque on the intake manifold bolts. You say you've been building the engine for a while, did it get a bore job? It's possible the cylinder water jacket cracked near the bottom of the cylinder, just below the rings while being machined.
Engine: tpi 350
Re: water in oil
problem solved, after pressurizing the cooling system overnight and then pulling every spark plug, found that there was no water in the cylinders. took the intake off and the rear water ports on the head were leaking. replaced the intake gaskets and all is good. apparently this is a common problem. hope this might help someone. have a great day!!
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Re: water in oil
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
