electric fans run constantly
I have dual electric fans on my 87 iroc 305tbi, As soon as i turn the key on they come on and won't shut off. i found the fan control sensor in the passenger side. the previous owner plugged it. i grounded the wire and the passenger side stays on constantly with the drivers side. Any suggestions to what could be causing this?
Car: 90 formula
Transmission: auto
Re: electric fans run constantly
the switch to turn them on prolly went bad and the previous owner just wired them to come on when the key is on. thats what i did.
Car: 87 GTA
On both the my 90 RS & 92 RS, I had spliced in an extra wire on the firewall relay, to ground out & run the fan key on=fan on.
During the summer I'd ground that wire. During the winter (if i remembered) I'd disconnect that extra wire & they'd turn on & off like stock, controlled by the sensor.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Second, the single fan for TBI was only run by the fan switch in the passenger head or by the A/C (238°F on temp).
An 87 dual fan setup (TPI) would have the ECM - A/C controlling the primary fan (220°F) and the secondary would run only by the fan switch (238°F).
As a guess, you may have a swapped in dual fan setup rigged to just run.
eightsixseven
Dec 16, 2024 01:50 PM
bad, constantly, constently, electric, elevtric, fan, fans, l98, run, running, runs, transmission, wiring
