Swirch to R134a ?
Old May 25, 2010 | 09:18 PM
Bota 65's Avatar
Car: 1987 Formula
Transmission: 700 R4
Axle/Gears: 3.42 L/S
Swirch to R134a ?
Hello all, I have an 87 Formula with 95k miles and the compressor is about to fail. It has a bad vibration at idle and it appears to be leaking the oil out of the front. I am thinking of switching it to R-134A because if the obvious price issue. Can someone please tell me what components that i will need to swap besides the compressor? I don't know if i need to change it all or just certain pieces. Thanks in advance.
Old May 25, 2010 | 09:37 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Re: Swirch to R134a ?
I have changed over 3 vehicles that I own. I did not have any major failures, just a leak that caused me to loose a bunch of r12. I bought kits that had oil that you force in through the low pressure side. Bypass the low pressure switch, and fill with 134a. I did not replace any parts. You do need to evacuate all the old R12. There are several ways to do it, but it should be recovered by the proper method.
Old May 26, 2010 | 05:10 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
I would consider an accumulator, orifice tube and O rings the minimum to change out during a R134 conversion.
Old May 26, 2010 | 06:28 AM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Don't forget the dryer there cheap and will make the system more efficient.
Old May 30, 2010 | 09:15 AM
Bota 65's Avatar
Car: 1987 Formula
Ok thanks everyone i will try today.
m00n420
Sep 11, 2015 02:39 PM
Ward
Aug 24, 2008 04:14 PM
92GTA
Jul 30, 2007 11:57 PM
DragRacer383
Jun 4, 2007 02:58 AM
327_TPI_77_Maro
Apr 11, 2006 07:13 PM
