What else do i need?
I finally fixed the vacuum leak so now i have air blowing through the vents! So now what will i need to hook the ac up? The previous owner said all i need to do is the an AC hose and some refrigerant and id be good to go. I have the consensor, line, and the ac hose, but the ac hose is from a s10 and wouldnt fit... Could anyone please tell me if i need anything else and how do i check for leaks?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Global Cooling
If the system has been open you should replace the dryer.
Once you have done that and the correct AC hose you should use a pump to evacuate the system of air and moisture.
Now you’re ready to add oil/refrigerant.
You can check your work for leaks with soapy water.
Happy Racing!
I I’ve NEVER Hit The Wall! - The Safer Barrier Prevented It
Happy Racing!
