Taurus fan
Old Jul 10, 2010 | 09:31 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Taurus fan
did some searching and found some info about the early 90's taurus fan install on 3rdgens.
FYI At some point in my car's life it was converted to single fan for some reason. The fan switch used for dual fan is still in the passenger side of the block unplugged
here and there some people were talking about drawing too much current or not.
and also I've read that they are 2 speed fans, how would I set that up in my car, or would I just wire it to the highest speed. if the latter, how would i do so?
just looking for some clarification and didn't want to bump 4yr old threads.
Thank you to all.
Old Jul 10, 2010 | 09:45 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Taurus fan
Yes they draw allot of power and needs to be wired right, it draws near 80 AMP on start up then drop to the 30s. But thats what makes it a bad azz fan in high demand. Makre sure and get all its wiring n stuff for the 2 speed n temp switch.
Would like one but don't got one so I can't provide more then that.
Long as its works, its money in the bank, can always be resold for a good price.
Old Jul 10, 2010 | 10:08 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Taurus fan
Looking into this myself in case the mods I'm doing do not work. As I understand it the low speed fan portion draws something like 17 amps. The high speed portion of the fan draws around 35+ amps depending on the situation.
Here is an interesting fact. The more cfm the fan moves the more amperage it takes to run the motor. Now if there is a restriction in front of the fan such as a radiator the fan cannot move as much air and it will draw less amps. The higher the restriction the less cfm the fan will move and the less amperage the motor will draw. I believe that is why you see some differences stated for the Taurus fan amperage. Running one on the bench and mounted to a radiator are two different situations.
IMHO if one was to install one of these Taurus fans I believe it would be a good idea to upgrade your alternator to a higher amperage one. Especially if you are running A/C and other electrical appliances. I also believe the factory supplied relays and circuitry are probably OK for the low speed side of the fan. However for the high speed side of the fan you will need a minimum of a 40 amp relay and heavy enough wiring to support the amperage.
Old Jul 10, 2010 | 10:13 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Taurus fan
I have a fan off a Lincoln Mark VIII. Some say its the same fan as the taurus but I think the Mark VIII moves a litle more air. Anyways, I run 2 relays to handle it. I also ran a 30 amp fuse going to each relay. I have since changed to one fuse. I'm going to try a single 40 or 50 amp fuse. It will blow a 25 amp fuse. It does move an extreme amount of air though.
Old Jul 10, 2010 | 10:49 PM
Car: 1989 GTA
Engine: 369 TPI
Re: Taurus fan
Yes the Mark VIII does move more air and requires more amperage to run it even though the motor may be the same as on the Taurus. I don't have the room to use the Mark VIII as I believe it is 6" thick and can be cut down to 5 1/2". I have seen the Taurus fan measured between 4.5" and 4.75". That will fit in my car if I need to go that route.
Old Jul 10, 2010 | 11:05 PM
built91Z28's Avatar
Re: Taurus fan
Heres a pic of my car. It looks like it may be a little under 6 inches. It is a tight fit though.
Old Jul 11, 2010 | 06:49 AM
Car: 1986 IROC-Z28
Re: Taurus fan
Sweet guys thanks!
Old Jul 11, 2010 | 09:30 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Taurus fan
Using an aftermarket fan controller could significantly help with the initial amperage draw. Although I'm just running a stock fan, I have a Flex-a-lite fan controller. It initializes the fan ON with only 65% power, runs the fan at this reduced rate for 2-3 minutes, and then kicks in at 100% ONLY if the temps have not dropped at that point. I'm sure some other fan controllers have similar function as well.
I've also read where folks only wire in the low speed of the Taurus fan to the switch or controller. Then, they wire the high speed to a toggle - that way they can utilize the low speed setting automatically, and only use the high speed setting when need an extra boost. Initial amperage draw would be significantly less since the high speed is being controlled via toggle and (one would assume) was only being switched on when excess heat was noticed (the low speed would already be on at that point, thus switching the high speed on would be just the difference in amperage draw between the two, and not a huge draw all at once).
Old Jul 11, 2010 | 09:46 AM
Car: 1986 IROC-Z28
Re: Taurus fan
do you have more info on where to find the flexalite/difficulty of install?
Old Jul 11, 2010 | 10:01 AM
Car: 1992 RS
Engine: Carbed 350
Re: Taurus fan
Got mine from summit - it's expensive at $100 - but I've had mine 4+ years now and it's been the best $100 I've spent. Was really easy to wire, comes with everything needed. Think mine is the 31165.
Old Jul 11, 2010 | 10:05 AM
Car: 1992 RS
Engine: Carbed 350
Re: Taurus fan
http://www.summitracing.com/parts/FLX-31165/
Old Jul 11, 2010 | 05:11 PM
Car: 1986 IROC-Z28
Re: Taurus fan
thanks! so it says 220 is the max temp to turn it on...will that cause issues with using a stock 195 t-stat?
Old Jul 11, 2010 | 06:03 PM
Car: 1992 RS
Engine: Carbed 350
Re: Taurus fan
No.
Old Jul 13, 2010 | 01:49 AM
Car: 1986 IROC-Z28
Re: Taurus fan
Originally Posted by camaronewbie
No.
so if it comes on at 220 what temp would it shut off at? ..with the tstat starting to open at 195..doesnt seem there is much of a range between tstat and fan
Old Jul 13, 2010 | 01:55 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Taurus fan
read this, it give good info on how a t-stat works and temp
http://www.carnut.com/ramblin/_cool3.html
Old Jul 13, 2010 | 02:14 AM
Car: 1986 IROC-Z28
Re: Taurus fan
thanks, but i didnt really get an answer
Old Jul 13, 2010 | 10:31 AM
Car: 1992 RS
Engine: Carbed 350
Re: Taurus fan
220 - 195 = 25. That's plenty of range. But most of us have swapped to the 180 stat also. But that's all part of the advantage with an adjustable controller - it's adjustable!
Me for instance, I live in NC - not a terribly hot or cold climate. But the last few years, the winters are getting colder, and the summers getting hotter. In June 2010, we set a new record with 21 out of 30 days with temps above 90, and 17 of those 21 the temps were above 95, and 4 days were actually above 100! June is historically a month of high 80's, not high 90's, and certainly not 100's! Winters have been colder as well - not across the board really, but each winter we are getting more periods of 10 degree lows and 30 degree highs, where we used to very rarely see lows below 30 and highs below 45. Global warming, earth shift on axis, or whatever the excuse of the day is, the weather is much different here than it was 30 years ago.
So, I've started spring/fall swaps. In the spring I swap in a 180 stat - helps keep the car temps lower in the high heat summer periods, but it's not overkill like a 160. In the fall, I swap in a 195 - helps keep temps a bit higher so I can have some heat in the car! The adjustable controller makes it easy to adjust the fans accordingly.
The fan is really only cooling the fluid in the radiator. When the stat opens, the cooler fluid is introduced into the block, and the hotter fluid is transferred to the radiator. If the fan comes on way before the stat opens, no big deal really - it's just cooling the fluid in the radiator further. But you'd want the fan to come on just before the point that the stat opens I would think - since the open stat is now transferring hot fluid into the radiator, and it needs cooled as it's running through the radiator. Plus, there's no reason to introduce the cooler fluid from the radiator into the block if it's really not that much cooler, so you'd want the fan to come on slightly before the stat opens to ensure the radiator fluid is cooler.
Maybe that's false logic - hell I'm no expert! But I do know that every engine I ever had, whether Nissan or Chevy or Ford or whatever, they all seem to run better at cooler temps. But I do understand the balance between cooler op temps and efficient fuel burn as well. Although GM designed with a 195 stat stock, I think that 20+ years later the world has changed - it's hotter out there! More cars making more heat, more pavement creating larger heat islands, global warming, all those things. GM designed the cars hotter to assist in better fuel burning (back then). But it's well apparent from reading threads here and elsewhere that most folks get better results with a lower (180) stat these days. And most of us have made modifications that alter general underhood temps anyway (like headers) - we have to be concerned with other implications such as fuel vaporizing and such, not just internal engine temps.
OK - enough already!
Old Jul 17, 2010 | 07:39 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Taurus fan
Hey man, I was thinking about doing the taurus fan conversion on my car. Can you send me some more info or give me a better idea on how to wire the thing? Could i still use the factory wiring and or the factory relay? I would also like to use a toggle switch for the high speed setting. Let me know . My email is o.sebastian33@yahoo.com
Old Jul 17, 2010 | 09:37 PM
Car: 1989 GTA
Engine: 369 TPI
Re: Taurus fan
You might be able to use the factory setup for the low power side of the fan. For the high power side of the fan you definitely need some aftermarket circuitry that will hold 40+ amps.
Old Jul 18, 2010 | 08:26 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: Taurus fan
i have used his stuff in the past with good luck. he has a controller for the 2 speed fans. these controllersw turn the fans on slowly and then ramps them up for a lot less draw.
http://www.dccontrol.com/fancontrol.htm
Old Jul 18, 2010 | 12:56 PM
Car: 1989 GTA
Engine: 369 TPI
Re: Taurus fan
That looks like a nice unit. I have saved it incase I have to go the Taurus fan route.
Old Jul 20, 2010 | 03:07 PM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
Re: Taurus fan
How is the Lincoln Mark VIII cooling fan compared to LT1 and LS1 dual cooling fans?
I have been looking for LT1/LS1 cooling fans (in Iceland) with no luck, I know of few Lincoln cooling fans and if they are as good or better it will save the day
Old Jul 20, 2010 | 05:04 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Taurus fan
get the lincoln or mark fan. it will cool really well.
Old Jul 21, 2010 | 04:37 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: Taurus fan
How thick is the taurus fan?
I swapped my stock dual fans to 2 sum-4902 ( 1107cfm )....because I needed the space for my 12rib setup, all I can say is stock fans move alot more air than the summit ones and my car is getting a little warmer than I like.
Now I want to upgrade and looking into a taurus fan instead.
/N.
Old Jul 21, 2010 | 04:55 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Taurus fan
i have heard that they are near 6 inches deep but can be cut down to like 5 something.
Old Jul 21, 2010 | 05:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Taurus fan
I think the fan is less then 4" deep. It's not nearly 6" deep.
I have one on my TA, and i've only wired it up to the low speed. I've never had any problems with temp issues. I used a solenoid, and a 30A maxi fuse I believe. Runs good. I could have wired up a switch to use the higher speed vs lower speed depending on switch position, but I never bothered.
I've got another one in my garage now, to be used on my buddies Monte Carlo (305 LG4) in the near future too.
Old Jul 21, 2010 | 05:54 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Taurus fan
actually there are different models of the fans. there is a taurus fan and a mark 8 fan. one is 6 inches deep and the other is thinner.
Old Jul 22, 2010 | 03:40 AM
Nonni's Avatar
Car: 86 T/A
Engine: ZZ383
Re: Taurus fan
I found this on another site:
First off they were ALL tested at Battery voltage (12.5v)
first and then with my truck running with a 30ft 4 gauge wire from my battery 14.5v
Not the exact numbers they fluctuate from 150 to 250 cfm this is an average
Battery operated
LS1 FAN SHROUD
1 fan turned on - 4800 cfm
2 fans on - 9500cfm
LT1 FAN SHROUD
1 fan turned on - 5000 cfm
2 fans on - 8700 cfm
1999 Dodge Stratus (both fans are always on - 2 speed)
Slow speed - 3700 cfm
High Speed 9000 cfm
1996 Ford Taurus (1 fan two speed)
Slow speed - 2800 CFM
High speed - 5600 CFM
Alternator Powered
LS1 FAN SHROUD
1 fan turned on - 5100 cfm
2 fans on - 10500cfm
LT1 FAN SHROUD
1 fan turned on - 5200 cfm
2 fans on - 9500 cfm
Slow speed - 4200 cfm
High Speed 10400 cfm
Slow speed - 3200 CFM
High speed - 6000 CFM
According to this I should use LT1 or LS1 fans if possible. I am sure that the Mark VIII fan is more than enough though
Old Jul 22, 2010 | 08:42 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: Taurus fan
those numbers seem a little high to me.
Old Jul 22, 2010 | 01:07 PM
Car: 1989 GTA
Engine: 369 TPI
Re: Taurus fan
From what I have seen posted the Lincoln Mark Vlll fan is around 6" thick and can be trimmed to 5.5". The Taurus fan is around 5" and can be trimmed to maybe 4.5" at most.
Interesting on the cfm numbers. I visit the LS1 forums and there is talk about them going to the Taurus fan to solve their overheating problems.
Old Jul 22, 2010 | 01:12 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Taurus fan
i have ls1 fans. although they cool pretty well i have had a mark 8 or rf-86 fan on a ford truck i had with a two speed controller and man that thing can move a lot of air. from my experience it moves more air than the ls1 fans i have. i am looking for a really good deal on a mark 8 fan now.
Old Aug 17, 2010 | 02:19 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Taurus fan
Yea those CFM #'s on the LS/LT fans has to be way off.
5100 CFM from single 12" fan, then an 18" fan on low, and 6000 CFM on the higher speed.
Old Nov 1, 2011 | 02:06 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Re: Taurus fan
awsome ideas
Old Jun 25, 2012 | 09:18 AM
Car: 1986 IROC-Z28
Re: Taurus fan
Completely forgot I had made this thread a couple years ago..I just got a two speed fan out of a 95 sable from the junkyard, plan on wiring it to low speed for now to test it out. I'll update when I start working on it tomorrow.
Old Jun 25, 2012 | 04:01 PM
Re: Taurus fan
If you decide you want to run the high speed on the fan. I recommend this
http://www.summitracing.com/parts/RFW-AR70/
Cause a 30amp fuse and a 40a relay will not cut the mustard.
I use a temperature switch in the pass head to ground the relay to turn the fan on at 185*
Old Jun 25, 2012 | 04:37 PM
Car: 1986 IROC-Z28
Re: Taurus fan
Cool...if I just wire low side to the factory stuff and high side to a toggle what gauge wire/size relay/ inline fuse should I buy so I can just wire it up myself?
Old Jun 25, 2012 | 06:42 PM
Re: Taurus fan
I didn't wire the low side to the factory wiring, I wasn't sure it would be heavy duty enough for it. I was running a 40a relay/30a fuse on 12ga wire for the low speed, that was the largest I could find locally. That Ron Frances kit I have now is a 70a relay/60a fuse with 10ga wire, that is running the high speed nicely. The Ron Frances kit is the only thing I have found that is heavier than the setup I had on the low speed.
Old Jun 25, 2012 | 08:52 PM
Car: 1986 IROC-Z28
Re: Taurus fan
thanks!
Old Jun 26, 2012 | 06:18 PM
Car: 1986 IROC-Z28
Re: Taurus fan
One of the best mods I've done...works great even on the low power setting.
Old Aug 31, 2012 | 03:31 AM
the209bnr's Avatar
Car: 1984 Pontiac Trans Am
Engine: L69
Transmission: THM-700R4
Axle/Gears: 3.73 Posi
Re: Taurus fan
subscribed
Old Sep 2, 2012 | 08:43 PM
the209bnr's Avatar
Engine: L69
Re: Taurus fan
I just picked up a Mark VIII fan from pick and pull, what else would I need to complete this swap?
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
