Dyson Fan
Old Jul 11, 2010 | 11:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Dyson Fan
Anyone see the Dyson fan? Really cool - no blades! Pushes air by way of intaking a small amount of air though an enclosed impeller, then passes it over an airfoil thus 'speeding' the airflow, the result is air blowing at 15 times the initial airflow of the impeller, but NO BLADES - it just blows out of a round housing - really cool. Wonder if it could work for an electric cooling fan for a car. Would have very little amp draw I'd imagine, no blades to 'cut up' the air as it's passed through, so a steadier stream of airflow, and no loss of fingers! Check it out at www.dyson.com
Old Jul 11, 2010 | 11:51 PM
Stephen's Avatar
Car: 87 GTA
Re: Dyson Fan
And I'd be willing to bet that there is a fan.....In the base.
Look at all the vents in a circle. Fan in the base pulls air in, blows it up to the ring on top, which has a slit in the ring to blow the air in one direction.
They try to claim no fan. I call ! The fan is simply hidden from direct sight & line of hearing.
Old Jul 12, 2010 | 01:03 AM
Car: 1992 RS
Engine: Carbed 350
Re: Dyson Fan
Yeah, there is a small fan in the base that pulls air in. The trick to it is magnifying it through the use of the airfoil. I'm not thinking it would actually push or pull more airflow than a standard bladed fan - but from the pictures I had the impression that it might do it way more efficiently. It makes sense when they discuss the buffeting of the air, how a blade cuts the air into chunks, and thus literally blows 'chunks' of air out. Whereas this design would tend to maybe hold a steady stream of air movement across the whole diameter and continuously outward maybe, producing a less interrupted airflow since it's not getting cut up. Was my weird thought anyway. It is a cool design, I'll have to see if there's a local shop around where I can experience it first hand.
Old Jul 12, 2010 | 06:40 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Dyson Fan
They had some set up at Best Buy last time I was in there. Neat fan. But at $300 a bit too pricey for me.
Old Jul 12, 2010 | 07:40 PM
Car: 1992 RS
Engine: Carbed 350
Re: Dyson Fan
Oh hell yeah - my $15 Walmart fan does just fine! I just thought it was a neat design, and that maybe such a design could be utilized in the cooling of an engine.
Old Jul 14, 2010 | 12:13 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Dyson Fan
awesome looking fan and idea, but size would be pretty prohibitive due to the design.
Old Jul 15, 2010 | 08:39 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Re: Dyson Fan
There are compare and test videos on youtube already. Fan looks cool but not $300 cool. It's also about as noisy as a regular fan and works no better, about the same. I'll wait for the knockoffs.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
