A/C R12 to R134 Conversion
Old Jul 31, 2010 | 07:39 PM
jpearsall187's Avatar
I am repairing my A/C system in my 88 IROC. I am putting in a new accumulator, orifice tube, o-rings, and a new compressor. I then plan on recharging with PAG oil and 134a. My question is, what exactly is in a retrofit kit? From what I can see, the only difference is the valves, but the manifold gauge set I have connects directly to the existing valves already in the vehicle, and I can recharge through the manifold guages. So, would it be really necessary to change the valves? (Or am I missing something and have the valves already been replaced?)
Old Aug 1, 2010 | 01:05 AM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Re: A/C R12 to R134 Conversion
what do your valves look like?
Old Aug 1, 2010 | 08:15 AM
siduramaxde's Avatar
Car: 86 berlinetta
Engine: 383
Transmission: built 700r4
Axle/Gears: 3.42 zexel torsen
are the valve you have now quick diconnect? If so, they have already been changed over. I like the 134 quick disconnect valves. Don't forget to pull a vacuum on the system before you charge it.
Linson
Oct 24, 2025 02:00 PM
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
