Color and location of wire to coolant sensor
Old Aug 14, 2010 | 12:50 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I had to rig up a switch a long time ago to manually turn on my cooling fan. I am now trying to fix it correctly but I cut the wire going to the pigtail of the coolant sensor on the passenger side of the engine. Can anyone tell me the color of that wire and where I may find it again.
Old Aug 14, 2010 | 03:47 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Color and location of wire to coolant sensor
Green with white stripe. Wire comes from fan relay by brake booster, I think travels in large wire bundle that goes along the top of the pass. valve cover, then goes down behind AC compressor below exhaust then back to sender, or something like that. As long as it gets to the relay without melting you should be good
Old Aug 15, 2010 | 10:29 PM
Car: 92' RS
Engine: LO3
Got it thank you.
Unfortunately the conector started smoking-melting when I turned the car on thanks to its proximity to the headers. Looks like I will need to come up with another plan.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
87350gtanj
Aug 8, 2015 10:32 AM
