Pusher Fan for my AC Condencer.
Old Aug 24, 2010 | 06:36 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Hi, i want to ask u guys were can i find a good pusher fan that would be good to mount infront of my ac condencer so it can push the hot air through the radiator so the original puller fan can pull it out. While in the highway with the ac on my car used to stay around 200-220 id say normal temp, but i was missing the air dam now i manage to get one from the junkyard and it will now stay between 180 and 200 at highway speeds even if its 90 outside like always here in miami, problem is as soon as i go into traffic temps will reach wellover 240 and even have gone till 260 according to the original gauge, anyways im forced to turn the ac off so the car can cool down, it is an issued considering how damn hot is outside. What i wanna do is hook up a pusher fan infront of the ac condencer that will turn on with the other fan so it can keep hot air out of the condencer thus not heating up my radiator and making the temps go up, the original single fan just cant do it alone.
The reason im asking is cuz while at the junkyard i saw an 82-85 v6 bird that had a small pusher fan infront of the ac condencer, is that original or a mod ? Now if i do this can i just hook the pusher fan with the original fan? Or will it mess up a fuse or something cuz of the extra load. Another thing i could do is hook it up to an aftermarket switch that turns on automatically when car reaches certain temp.
Old Aug 24, 2010 | 11:33 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Pusher Fan for my AC Condencer.
Mid 80s Corvettes had these too. Might check around on Ebay and such for one.
Old Aug 25, 2010 | 02:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Pusher Fan:A Spectator Offers To Move The Crowd Of People So I Can Leave Faster
Don’t do that.
Wire a relay so the relay energizes as soon as the AC is on.
That way you will increase the performance of the AC.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Aug 25, 2010 | 06:15 PM
DSGx's Avatar
Engine: 305 TBI L03
Re: Pusher Fan:A Spectator Offers To Move The Crowd Of People So I Can Leave Faster
Originally Posted by NINÅ
Don’t do that.
Happy Racing!
So what i should do is, get the fan then hook the ground well to a ground ofc, the possitive to one of the big terminals on the relay then the other big terminal to the possitive in the battery, now the other terminal on the relay goes to any switch type i wanna use, were can i hook the hot wire to? I want my condencer fan to kick on as soon as my AC is on but i dont want it running with my other fan if i got the ac off, or will i be better off using a temp switch or will that cause the fan to keep running even when i shutoff the car until the temp goes down ?
Old Aug 30, 2010 | 09:20 AM
NINÅ's Avatar
Transmission: 765R4
If We Add One More Fan This Thing Is Going To Take Off !
You will have to add a relay.
Connect one wire of the relay coil to the AC cycling switch (the
light green wire) (the switch is on the accumulator).
Connect the other of the relay coil to ground.
Connect one power terminal of the relay to the battery thru a 25 amp fuse.
Connect the other power terminal of the relay to the pusher fan 12 volt input.
Connect the other pusher fan wire to ground.
will i be better off using a temp switch or will that cause the fan to keep running even when i shutoff the car until the temp goes down?
You’ll know after the pusher installation.
If you need to, then connect a temperature switch to the coil of the new relay to keep it energized until cool down.
You’ll have to add a diode between the temperature switch and the relay to prevent interaction.
Happy Racing!
He Must Have Been Be Cheating - Because I Was And He Almost Beat Me.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
